Injector 1 and injector 3 is acting up, but your coil pack is bad, so fix that first then see what happens, because the coil might be causing the other problems with the injectors, so it looks like you'll have to replace your coil pack and then 1and 3 injectors.
SPONSORED LINKS
Tuesday, May 20th, 2008 AT 3:25 PM
