HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Dodge
Intrepid
Engine
Symptoms
Not Running
SPONSORED LINKS
1997 Dodge Intrepid
LOGANSEVEN7
MEMBER
1997 DODGE INTREPID
Dodge, Intrepid, 1997 110,000 miles
the car will not start.
I the car will turn over.
There is spark to the plugs.
There is fuel to the cylinders, When I pull the plugs they are wet with fuel.
Any Idea
SPONSORED LINKS
Sunday, February 26th, 2006 AT 6:19 PM
LOGANSEVEN7
MEMBER
I have scanned for the trouble codes. There are no Codes stored.
Sunday, February 26th, 2006 AT 6:21 PM
JPAM
MECHANIC
Pull the plugs. Which you've
Fuel soaked = electrical problem (or a leaky injector)
dry: full delivery.
SPONSORED LINKS
Sunday, February 26th, 2006 AT 8:22 PM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
1997 Dodge Intrepid Turns Over But Won't Start
I Have Had The Car For About One Year With No Problems. Tune Up-belts-hoses-spark Plugs And Wires All Replaced. My Notmal Gas 24mpg. On...
Asked by
dallann
1 ANSWER
1997
DODGE INTREPID
VIDEO
How to fix an engine that wont start
Instructional repair video
GUIDE
Engine Not Starting
Over the past 20 years at 2CarPros we have identified the top problems that are easily fixed. This guide can save you a trip to the repair garage or calling a tow truck and...
1997 Dodge Intrepid Car Won't Start.
I've Put A Fuel Pump In New Fuel Injector A New Coil. It Still Won't Start. Can You Tell Me What Else I Can Do. I'm Doing The Work On My Own...
Asked by
moria
1 ANSWER
1997
DODGE INTREPID
1997 Dodge Intrepid My Car Wont Start
I Have A 97 Dodge Intrpepid And It Wont Start. When I Was Driving It Turn Off My It Self And Little Bit Of Smoke Came Out On The Right Side...
Asked by
sergionc
1 ANSWER
1997
DODGE INTREPID
1997 Dodge Intrepid No Start
Hello, This Car Has A 3.5 Doc. I Changed The Fuel Pump And Filter And Pump Relay. Also Changed Crank And Cam Sensors And Asd Relay. Fuel...
Asked by
tillamookhead
1997
DODGE INTREPID
1997 Dodge Intrepid Won't Start
My Intrepid Lost A Belt. After Replacing It The Car Did Not Run Properly, Pulled The Code And It Said The Cam Position Sensor Was Bad...
Asked by
dwester
1997
DODGE INTREPID
VIEW MORE
SPONSORED LINKS
Crankshaft Sensor Symptoms
Crankshaft Sensor Replacement
Online car repair manuals
