1996 Dodge Intrepid Engine idle is eradic
CRASHCAMCOR
  • 1996 DODGE INTREPID
  • 6 CYL
  • FWD
  • 141,000 MILES
I have a 3.3 engine that I have replaced all the fuel injectosr and the egr valve my car idles around 3500 rpm and when I drive it will keep on speeding up and is very hard to stop and keep stopped. How would I trouble shoot why is it idling the way it is?
Thursday, February 28th, 2008 AT 11:30 PM
BLACKOP555
  • 10,371 POSTS
Unplug your IAC module and see if that tames the idle down if not keep it unplugged and give hte engine a few revs and a restart with it unplugged.
If not then its not the IAC module if it tames it then the IAC is probably bad.
If not the IAC then check your pcv valve if it is plugged the vehicle will idle high.
Friday, February 29th, 2008 AT 7:09 AM
