hi there, we have been having issues with our intrepid. it seems to start right up, timing seems to be fine. When ever i take the rpms up over 2400, then the car seems to sputter, and looses power. I took the car to Autozone and here is what the troubleshooter printout said:(please note, the printout is hard to read)
Definition
BBCKP/CMP timing misalignment
Explanation
BBECM Detected the crank sensor is not aligned with BBthe cam sensor
Probable cause
BB1. - Intermittent connection
BB2. - Failed crank or cam sensor
BB3. - Engine mechanical condition
(not too sure if the BB are 00)
I have replaced the cam sensor and the crank sensor which didnt fix the problem, and when i popped the hood last night i noticed i could see a little bit of light (spark) coming from each spark plug coils. the spark seems more prominent as i increase the rpms. not too sure what to do next, any suggestions? thanks for your time.
Definition
Explanation
Probable cause
Aug 3, 2009 at 3:36 PM
