1995 Dodge Intrepid Fuel Pump
RICKBR55
  • 1995 DODGE INTREPID
  • 6 CYL
  • 135,000 MILES
I parked my car 1 night went out to start it the next day and noticed it showed no gas in it. I added 3 gals of gas and still showed nothing. I went to replace the fuel pump and none of the four wires were connected. I have tested the 4 wires and only the blue one has any power to it. All fuses seem to be fine.
My question is where does the wires run from when they leave the fuel pump. I am really lost here.
Friday, September 19th, 2008 AT 2:10 PM
DOCFIXIT
  • 18,828 POSTS
Need to know some stuff what engine 3.3 or 3.5
What color are the wires? Let me know I'll be on linr till 5pm EST
Friday, September 19th, 2008 AT 2:23 PM
RICKBR55
  • 5 POSTS
Iis a 3.3 the wires are green blue black with yellow stripe and black the blue wire is the only one that has any power My tester is supposed to show positive and neg on it.
Friday, September 19th, 2008 AT 3:25 PM
DOCFIXIT
  • 18,828 POSTS
The wires are in a terminal connector right? And it plugs into a connector that goes to pump/sender right? How did it get uncoupled?
The blue wire is the power feed from relay the black wire is ground G200 left kick panel. The green and bk/Y are for gas gague sender. If you have power on blue and ground on blk pump should run.
Friday, September 19th, 2008 AT 3:43 PM
RICKBR55
  • 5 POSTS
It got unhooked by me. I have no idea how the wires got broke or chewed or what ever happend to them. I have tried to splice in wires to make it work and can not get the pump to work. The only wire that shows anything is the blue wire the gas gauge works now but nothing else does
Friday, September 19th, 2008 AT 3:47 PM
DOCFIXIT
  • 18,828 POSTS
Put meter pos on blue and neg on black should show 12v+ if not groung is screwed. Take black wire ground to body pump on? If so drill hole put term on wire screw and you should be good to go.
Friday, September 19th, 2008 AT 3:56 PM
RICKBR55
  • 5 POSTS
Ok I have tried everything. I even got a new pug in that goes to the fuel pump. I have tried putting the grounds to the body and still the same thing. The fuel gauge works but not the pump. Any ideas?
Wednesday, September 24th, 2008 AT 2:55 PM
DOCFIXIT
  • 18,828 POSTS
Hi did you put a new pump in?
If there is power to pump and ground it should run. Rig up a power wire place it to pump and ground if it don't run then pump is bad.
Wednesday, September 24th, 2008 AT 3:21 PM
RICKBR55
  • 5 POSTS
The pump was tested before I put it in and it is fine. There is power to the blue wire only no power to the green wire the green wire is supposed to be for the fuel guage no power shows up on the green wire yet the gas gauge works
Wednesday, September 24th, 2008 AT 3:25 PM
