HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Dodge
Intrepid
Drivetrain
Transmission
Symptoms
STUCK IN GEAR
1994 Dodge Intrepid
YOUNGMARV
MEMBER
1994 DODGE INTREPID
6 CYL
FWD
AUTOMATIC
130,000 MILES
Car is stuck in first gear. If I cut off and restart it will go to second then go back to first what gives?
Monday, February 8th, 2010 AT 12:41 AM
ERNEST CLARK
MECHANIC
Your computer is detecting a problem with the transmission and is programmed to start your car in 2nd gear.
You'll have to have your computer scanned by someone who has access to a scanner capable of reading the tranny codes. (Any generic scanner won't do)
And you'll definitely need some tranny work. Sorry.
SPONSORED LINKS
Wednesday, February 10th, 2010 AT 9:35 PM
Please
login
or
register
to post a reply.
Related Transmission STUCK IN GEAR Content
1999 Dodge Intrepid Stuck In Second Gear
99 Dodge Intrepid, 170k Miles. Symptoms: Speedometer Stopped Working, And On The Next Turn As I Slowed Down The Car Stalled. I Put It In...
Asked by
donoghuechris
1 ANSWER
1999
DODGE INTREPID
Transmission Sensor
My Car Is Stuck In Second Gear, This Happened To Me 4 Years Ago. What Is The Part I'm Looking For Before I Call A Garage To Fix. The...
Asked by
staceyship
2 IMAGES
2000
DODGE INTREPID
Transmission Issues
My Car Is Stuck In Second Gear. I Can Shift It Just Fine Between Park, Reverse, And Neutral. When I Put It In Drive It Stays In Second. I...
Asked by
parisinmt
2001
DODGE INTREPID
1993 Dodge Intrepid Trans Stuck In 2nd
Transmission Problem 1993 Dodge Intrepid 6 Cyl Front Wheel Drive Automatic 85k Miles Need Some Info. Wifes 96 Intrepid Is Stuck In 2nd...
Asked by
blkknight
1 ANSWER
1993
DODGE INTREPID
2001 Dodge Intrepid Could My Transmission Be Going...
I Just Bought This Car.I'm Starting To Feel Like I Really Got Taken Advantage Of. But Anyways I've Had This Car For Alittle Over A Month Now...
Asked by
x.katay.x
1 ANSWER
2001
DODGE INTREPID
VIEW MORE
SPONSORED LINKS
Pilot Bearing Replacement
Transmission Replacement - Manual RWD
Throwout Bearing - Secondary Cylinder Replacement
Online car repair manuals
