1993 Dodge Intrepid trans stuck in 2nd
BLKKNIGHT
  • 9 POSTS
Transmission problem
1993 Dodge Intrepid 6 cyl Front Wheel Drive Automatic 85k miles
need some info. wifes 96 intrepid is stuck in 2nd gear, it wont up or down shift at all. can the tcm if bad cause this to happen?
Sep 29, 2009 at 2:34 PM
CH112063
  • 1,320 POSTS
The TCM does cause this to happen. You don't have alot of miles for a 96. If a sensor shows something is wrong with the control system or a slipping is sensed, the transaxle controller(TCM) does this to keep any damage from occurring. Check for codes. The operation manual and scan tool are available on this site. Let me know the codes you get, check the fluid and smell it first. Check fuses under hood in power center also. Ok
Oct 3, 2009 at 5:38 PM
