Replaced O2 sensors, fuel filter, spark plugs and wires. I have checked for vaccum leaks\gasket leaks\EGR and find none. Oil is clean as well. NO trouble codes found in the OBD I. I think it is either the coil or fuel pump. Coil costs less so it is next to go. I doubt it is the CAT because it runs perfect when started. Is there anywhere else to look?
SPONSORED LINKS
Tuesday, July 1st, 2008 AT 12:23 PM
