1993 Dodge Intrepid Heat
70,000 MILES • 6 CYL • FWD • AUTOMATIC
KMILLER55
The defrost blower is always on, only on defrost. I have no heat or air. Also it appears that the cooling fan does not go on. It also idles at a high rate. I think these are all related, but not sure where to start?
Jan 14, 2008 at 7:12 AM
MERLIN2021
  • 17,250 POSTS
Your defrost is on because the system will default to defrost when there is a vacuum leak. You must find and fix the leak. Open the hood and look for a thin black vacuum hose that appears to go into the car, trace this line, it is usually the leaker...If not check the control head for the heat/ ac/ happy hunting!
Jan 14, 2008 at 7:24 AM
