1992 Dodge Dynasty will not start
GENE2393
Engine Mechanical problem
1992 Dodge Dynasty Two Wheel Drive Automatic
I have a 1992 dodge dynasty that is currently not starting we just recently replaced the distributor cap and rotor because we thought they were bad, it cranks but does not start. We can not smell any fuel getting to the motor when we are pumping the gas and trying to start the car. What could this be?
Jan 25, 2010 at 1:12 PM
  • 75,988 POSTS
Do below it will tell you what's missing fuel or spark
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Jan 25, 2010 at 4:47 PM
