1999 Dodge Durango Delayed Shift
The level of the tranny fluid is good?
Only ATF + 4 transmission fluid used?
How often was the filter and fluid changed?
Check the fluid in nuetral.
I would remove the oil sending unit and install a pressure gauge and find out if it is an engine problem or a gauge problem.
To check your fluid, warm the truck to operating temperature, put the parking brake on, put the transmission inot nuetral. Remove the transmission dipstick, wipe it off, re-insert it and remove it a gain and look where the level is. There are indicators on the stick to show you where it should be.
Suggested Repair
Check the transmission fluid hot in neutral and confirm ATF+4 was used. Have the reported 3rd-to-4th shift malfunction and output speed sensor codes diagnosed by a technician, not just scanned at a parts store. For the oil-pressure gauge dropping at idle, compare the sender reading with a mechanical pressure gauge to determine whether the engine or the gauge is at fault.
Conversation Summary
The owner of a 1999 Dodge Durango 5.9L reported delayed shifts with engine roar, a check-engine light, and an oil-pressure gauge that drops to zero when slowing or stopping. The expert advised checking the hot transmission fluid level in neutral, confirming ATF+4 use, and retrieving codes. A parts-store scan later reported a 3rd-to-4th shift malfunction and an output speed sensor fault. The expert also recommended a mechanical oil-pressure test to distinguish an engine problem from a gauge or sender problem.
