1999 Dodge Durango Turn Signal Flasher Fix
TMIKE3
1999 dodge durango turn signal flasher location - The turn signal flasher needs to be replaced, but I can't find it. I've looked under the hood with the rest of the relays and fuses and also on the driver's side fuse block on the side of the dash. Can you tell me where it is on this truck?
Sep 29, 2007 at 4:24 AM
  • 55,819 POSTS
The turn signal flasher is located on the drivers side near the side kick panel. (diagram below) Please let us know if you need anything else to get the problem fixed.
Mar 6, 2021 at 3:58 AM
Suggested Repair
Look for the turn signal flasher on the driver's side near the side kick panel, then replace it there.
Conversation Summary
The owner of a 1999 Dodge Durango could not find the turn signal flasher in the under-hood relay and fuse area or the driver's side dash fuse block. The expert said it is located on the driver's side near the side kick panel.
