2003 Dodge Durango Low Oil Pressure
BCMFWB
I have a 2003 Dodge Durango SXT 4.7L V8. I had a seized engine and had a reman engine installed. After installation, my oil light came on. I had the oil pressure checked with a mechanical oil guage and found it to be around 6psi at idle at around 35-40psi at 3,000rpm. My mechanic suggested the oil pump that came with the reman engine may be defective, so I put a new oil pump in it. I also changed out the oil pressure sensor, and I am still having the same problem. The warranty company on the reman engine refuses to do anything because they say 6psi is a normal reading, however, it is apparently kicking the oil light on, so there is still a problem. Any ideas or suggestions? Thanks!
Jul 12, 2007 at 1:13 PM
MERLIN2021
  • 17,250 POSTS
it sounds like the rebuilder left out one of the internal oil pump galley plugs. I would remove the engine for inspection. Can you please shoot a quick video with your phone so we can see what's going on, that would be great. You can upload it here with your response.
Jul 13, 2007 at 1:48 AM
Suggested Repair
Remove the remanufactured engine and inspect it for a missing internal oil-pump gallery plug that the rebuilder may have left out.
Conversation Summary
A 2003 Dodge Durango with a newly installed remanufactured 4.7L engine has an oil-pressure warning light. A mechanical gauge reads about 6 psi at idle and 35-40 psi at 3,000 rpm. Replacing the oil pump and oil-pressure sensor did not help, and the warranty company claims the idle reading is normal. The expert suspects a missing internal oil-pump gallery plug and recommends removing the engine for inspection.
