evap canister location
AUTODUMMIE
my 2001 durango has the check engine light on. took it and had it checked and the two codes given where 0442 and 0445 which are a leak on the evap hose and a leak at the evap canister. problem is i can not find this canister or the filter on the valve cover. if some one could tell me where to look it would help. thanks for the help.
Aug 4, 2007 at 4:30 PM
  • 75,988 POSTS
[quote:1b3d8e99f4="autodummie"]my 2001 durango has the check engine light on. took it and had it checked and the two codes given where 0442 and 0445 which are a leak on the evap hose and a leak at the evap canister. problem is i can not find this canister or the filter on the valve cover. if some one could tell me where to look it would help. thanks for the help.[/quote:1b3d8e99f4]
The charcoal cansister is on the right bottom of the engine towards the front sitting down in the truck. The filter is w/the canister-its about a size of a coffee can
Good Luck!
Aug 4, 2007 at 5:50 PM
