2006 Dodge Durango electrical /computer
39,000 MILES • V8 • 2WD • AUTOMATIC
MPOCO
once a week the battery will be dead on the car mostly on sunday mornings when trying to go to church, i replaced the battery but that did,nt help some times the lights will flicker and the wipers will come on after you jump it off i also had the alternator checked and it was good any help would be grateful. :idea:
Dec 30, 2007 at 3:07 AM
OLDTECH2
  • 64 POSTS
Sounds like you've got something staying on. Probably in the turn signal stalk switch.
Disconnect the ground (neg) side of battery and put a test light between the cable and the batt. You'll get a low glow from the radio etc with the "keep alive" memory. If it's got a bright light, then you've got a draw from something on. Pull fuses 1 at a time to find the circuit. Then you've got to figure out what's allowing the circuit to stay on.
Good luck!
Dec 30, 2007 at 12:02 PM
