2003 Dodge Durango transmission shifting problem
80,000 MILES • V8 • 4WD • AUTOMATIC
WALTB208
My durango has had an intermittent problem where it doesn't always drop back to 1st gear after coming to a stop. When I try to start moving I can tell it is in a higher gear, I drop it into L1 and it is fine until it happens again. The transmission was replaced about 10k miles ago under warranty, it is no longer warranted. My mechanic said it could be a trans solenoid. I am very handy and would opt to fix it myself.... what do you think?
Thanks,
Walt
Jun 10, 2009 at 11:36 AM
BMRFIXIT
  • 19,053 POSTS
I would suspect the solenoids too
need to conform that by scanning for codes and or checking the tranny data
also would suspect speed sensors
The Input and Output Speed Sensors are two-wire magnetic pickup devices that generate AC signals as rotation occurs. They are mounted in the left side of the transmission case and are considered primary inputs to the Transmission Control Module (TCM).
OPERATION
The Input Speed Sensor provides information on how fast the input shaft is rotating. As the teeth of the input clutch hub pass by the sensor coil, an AC voltage is generated and sent to the TCM. The TCM interprets this information as input shaft rpm.
The Output Speed Sensor generates an AC signal in a similar fashion, though its coil is excited by rotation of the rear planetary carrier lugs. The TCM interprets this information as output shaft rpm.
The TCM compares the input and output speed signals to determine the following:
Transmission gear ratio
Speed ratio error detection
CVI calculation
The TCM also compares the input speed signal and the engine speed signal to determine the following:
Torque converter clutch slippage
Torque converter element speed ratio
Jun 10, 2009 at 11:17 PM
