will not shift out of park when I depress the brake pedal. replace the brake pedal switch.
Jun 12, 2017 at 8:20 AM
HMAC300
✓Experienced Mechanic
check all fuses under hood and in car you may have a blown fuse on shift interlock then check for any disconnected cable/linkage.
Jun 12, 2017 at 8:36 AM
BESSIE PARKER
MEMBER
I checked all fuses last night and they were good would the shift interlock fuse be located in a different place?
Jun 12, 2017 at 8:48 AM
HMAC300
I made a mistake It does not have a fuse this may be a computer issue so a mechanic will need to look at it.
Jun 12, 2017 at 10:53 AM
