2003 Dodge Durango Bad shake
2003 DODGE DURANGO
40,079 MILES • V8 • 4WD • AUTOMATIC
DURANGO72
I just started having this problem a few days ago with my SUV shaking. It happens on the start go at low speeds. Once I get to 35-40mph it is not noticable. It also shakes when I apply the brakes and get near a slower speed. While at higher speeds on the hwy my steering wheel is out of alignment.
Is this all based on getting an alignment or just replacing the tires?
Apr 7, 2008 at 2:33 AM
SGTROD07
  • 5 POSTS
THAT YEAR DURANGO HAS A RECALL CHECK TO SEE IF YOURS QULIFIES YOU CAN GO TO DODGE.COM AND CHECK THE RECALL STATUS IT WILL ASK YOU FOR VIN AND TELL YOU ALL THE RECALLS FOR YOUR MODEL.THE UPPER BALL JOINT HAS BEEN KNOWN TO SLIP OUT OF PLACE SO I WOULD HAVE IT CHECKED OUT BY THE DEALER THEY WILL REPLACE THE PART FOR FREE AND LABOR IS ALSO COVERED IF THERE IS A RECALL ON YOUR MODEL IF NOT CHECK THE DRIVE ASSEMBLY AND HAVE YOUR VEHICLE ALLIGNED AND THE APPROPRIATE PARTS REPLACED
Aug 25, 2008 at 7:41 AM
