2002 Dodge Durango Power steering fluid
88,000 MILES • V8 • 4WD • AUTOMATIC
SERG873
The Power steering fluid is leeking from somewhere, can i use any type or Power steering fluid to refill?
Power steering fluid and Transmission fluid is the same?
How much it will cost to repair the leak?
Please advise,
Thank you very much,
Serg
Dec 11, 2007 at 3:25 AM
TOBYU
  • 89 POSTS
Dodge trucks are bad for this....
I have had two do it in 4 years.
Get some TransX transmission fluid additive....they make a powersteering one..but it is the same thing and you get less.....
Add about 10 oz of this to the power steering and top off with power steering fluid. I like actual clear looking power steering fluid....the specs say you can use tranny but I don't like to.
You can treat it two to three times with this TransX....you will probably see a big reduction is the leak by the second application.
Dec 13, 2007 at 7:32 PM
