outer tie rods
160,000 MILES • 5.2L • V8 • 4WD • AUTOMATIC
GABRIELLEK
Can you use any tie rods for a Durango or is there tie rods that are made specifically for 4wd?
Feb 13, 2016 at 6:19 AM
  • 31,937 POSTS
Ther will be tie rods designed specificaly for this car, normally where a car has a option for 2 or 4WD the 4 wheel drive component is different in as much as it will be made of heavier construction, i would only recommend using the correct part for this repair.
Feb 13, 2016 at 7:37 AM
