2002 Dodge Durango Battery Discharge Issue
85,000 MILES • V8 • 4WD • AUTOMATIC
STILINGM
For the last several thousand miles my battery life has decreased to rarely holding a charge more than 40 hours. I have replaced with a new battery several times, however, the problem persists. When I attempt to start the car after a short layover (40-60 hrs) in a garage in moderately cold outdoor conditions (40 degrees) it starts very hard, if at all. Anytime over 2 days, it will not start at all. The car will typically start when jumped, however, the charge does not hold. When trying to start the vehicle, touching the body results in shock. Any suggestions? Thanks!
Jan 7, 2008 at 12:59 PM
  • 31,937 POSTS
Check battery discharge by placing an amp meter between battery pos(+) and the battery lead this will show current draw. you want only about .15Amp if more pull fuses to locate circuit that has fault, do this with key off and doors closed, check for faulty alternator as well.
mark (mhpautos)
Jan 7, 2008 at 8:50 PM
  • 75,988 POSTS
You probably have a short in the electrical system that's eating up the battery
Jan 7, 2008 at 8:53 PM
