2000 Dodge Durango water pump bypass hose
2000 DODGE DURANGO
99,000 MILES • V8 • 2WD • AUTOMATIC
FLANARYK
I am changing the water pump on a 2000 Dodge Durange V8 5.9 Liter. The bypass hose that connects to the water pump is baked on. I would like to change the bypass hose but not sure how to access it. How can i change the hose?
Nov 10, 2008 at 12:52 PM
IMPALASS
  • 3,112 POSTS
Hello
If it is baked on and you are going to replace it (which I always do while I am there, the directions state
13. Loosen clamp at water pump end of bypass hose . Slip bypass hose from water pump while removing pump from vehicle. Discard old gasket. CAUTION: Do not pry water pump at timing chain case/cover. The machined surfaces may be damaged resulting in leaks.
If you can not break it loose, I cut the old off since I am replacing it anyway.
Nov 10, 2008 at 1:22 PM
