bypass hose
DBISS
Engine problem V8 Four Wheel Drive Automatic 120000 miles
How in the heck do you replace the water pump bypass hose with out having to remove the alternator/ac pump bracket?????
Dec 25, 2007 at 5:44 PM
SERVICE WRITER
  • 9,123 POSTS
Without seeing it it's hard to say, may have to remove it. One technique is to cut the hose in half and take one side out at a time....if that is possible....not always possible due to restrictions. You may need a set of long pliers to reattach new one and lightly lube the hose to help its slide on easier but it sounds lime you will need to remove the bracket
Dec 25, 2007 at 8:34 PM
CHARLIERMF
Yep that's what I did
Feb 8, 2018 at 8:16 AM
