2000 Dodge Durango Durango wont start
11,000 MILES • V8 • 4WD • AUTOMATIC
SHARIMAKO
My husband is a mechanic.. but he works on the construction equipment,,... he has been trying for the past two days to fix the Durango... When you turn the key it tries to turn over but wont start... He said there is no spark... He replaced the Engine Coil and the Ignition Pickup.. also replaced the battery..
Apr 21, 2008 at 3:34 AM
OLDTECH2
  • 64 POSTS
Have your husband cycle the key to the "on" position 3 times without hitting the start circuit. You should get a trouble code for an idea of what's wrong.
Dec 31, 2018 at 5:30 AM
BMRFIXIT
  • 19,053 POSTS
check and or replace crank sensor
check ASD relay and fuses
