Similar to another question asked in the forum. Antifreeze had broken down, got system flushed and shorlty after started to smell antifreeze when heating of cooling system was used. Took to local Dodge dealer to repair speed sensor on rear wheel and to have them pressure test cooling system (I had initially thought it was a heater core) The tested system & found no leaks, they then cleaned some box in the system and used "mr fridgy fresh?" in the process... The smell was gone for a couple days, but then returned. Any ideas on a final solution to this problem?
Apr 24, 2007 at 7:53 AM
