1999 Dodge Durango Starting problem
87,000 MILES • V8 • 4WD • AUTOMATIC
HAT_MAN6999
For some reason when I try to start my Durango when I turn the key nothing happens at all...and then if I turn it 5 times or so it starts right up.And other times when I turn the key,it tries to turn over for 1 second then nothing,and after 5 tries it starts.I have changed the battery terminals and checked the ground to the block,starter checks out good too.And I had the battery checked they said that was good as well.Any idea what the problem is?
Apr 6, 2009 at 1:24 AM
JAMES W.
  • 2,394 POSTS
Check for power in and out of the starter relay in "key start" position. If no input, check fuses. If no output, replace relay.
https://images.2carpros.com/forum/automotive_pictures/248092_99_Durango_starter_1.jpg
Apr 6, 2009 at 3:27 AM
