1999 Dodge Durango stalling
TRACIEROSS
Engine Mechanical problem
1999 Dodge Durango Four Wheel Drive Automatic 126,00 miles
my darango, dies at 5miles/75miles per hour out of the blue. I had the crank position sensor replaced and it continues to stall. After sitting anywhere from 10to45 mins. it will start again. I'll get 4 blocks or 45 miles down the road and it will stall at a stand still or a full run. On one occasion as I was coasting to the side of the road it started again and off we went. no one seems to know what the problem is and I cant afford to keep paying for guess'. Any help would be grateful.
Jun 17, 2009 at 2:15 PM
  • 110,248 POSTS
This could be a few things. When it does this, you need to check to see if the engine is getting both spark and fuel (when it won't start). One will most likely be missing.
Here are the how to's for checking both:
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
https://www.2carpros.com/how_to/how_to_test_an_ignition_system.htm
Let me know what you find.
Jul 17, 2009 at 10:12 AM
