1999 Dodge Durango Front signal light replacement
LVLIKEY
1999 Dodge Durango V8 Four Wheel Drive Automatic 180k miles
Hi! I recently blew a front signal light and am having troubles on how to get at it to replace it...Any help would be very much appreciated.
Feb 25, 2010 at 8:35 AM
BLUELIGHTNIN6
  • 16,542 POSTS
The lamp module must be removed after taking off the securing screw. The module is secured by a screw and incorporates the side marker bulb as well. Remove that screw then the module will pull out.
https://images.2carpros.com/forum/automotive_pictures/261618_0900c152800c0a68_1.jpg
After the bulb is accessed, turn it CCW 1 / 4 turn and remove it and the connector from the module. Pull the bulb out of the connector. Installation is the reverse of removal. Before installing the light bulb into the metal contacts, ensure that all electrical conducting surfaces are free of corrosion or dirt. Clean the bulb glass surfaces. To ensure that the replacement bulb functions properly, activate the applicable switch to illuminate the bulb which was just replaced. If the replacement light bulb does not illuminate, either it is faulty or there is a problem in the bulb circuit or switch. Correct as necessary. Install the module, noting that on some models it is located with slots and tabs which must be properly aligned. Install the securing screw.
Feb 25, 2010 at 8:51 AM
