Have no parking lights or dash lights when headlights are turned on. Replaced headlight and dimmer switches multiple times, once even tested the new headlight switch on another Durango to be sure. Of course, it works on the other Durango, but same issue still exists when installed on mine.
Can manipulate headlight switch to cause parking lights to come on by pulling switch out between off and 1st position (parking light position). They will stay on until the high beam lever is pulled back and held. Once this is done, both high beams and parking lights will stay on for a short time then trip. Once releasing high beam lever, the parking lights reset and come back on.
Have checked all grounds in dash.
Apr 29, 2009 at 4:13 PM
