2000 Dodge Durango Won't Start
KROSS1979
When we started the durango, the AC & power windows wouldn't work, then I shut the car off, and it wouldn't start again. I replaced the 50 amp starter/ignition fuse, and it burnt 3 of them in a row. and now it won't start. but the interior lights and the radio works. Please help! :(
Oct 4, 2007 at 3:12 AM
SERVICE WRITER
  • 9,123 POSTS
There is a starter relay in the power distribution box that I would check first. Sometime there is one similiar that you can swap it with.
Dec 31, 2018 at 5:31 AM
KROSS1979
My husband swapped the relay and it still burnt the fuses. He said he was going to have the battery tested next. Would this be your next move?
SERVICE WRITER
  • 9,123 POSTS
Sorry, I'm at work.
I would next disconnect the driver's power lock switch as it is tied into the ignition, then try it.
KROSS1979
my husband will try this tomorrow morning. thanks so much for your help so far!
Suggested Repair
The starter relay was already swapped and the 50-amp starter/ignition fuse still blew. Next, disconnect the driver's door power lock switch, which is tied into the ignition circuit, and try starting again. A battery test was also planned by the owner.
Conversation Summary
A 2000 Dodge Durango lost A/C and power windows, then would not restart after the 50-amp starter/ignition fuse was replaced and burned out three times. Interior lights and the radio still worked. Swapping the starter relay did not stop the fuse from blowing. The expert next advised disconnecting the driver's power lock switch because it is tied into the ignition, and the owner planned to try that.
