1986 Dodge Daytona Head Gasket Repair
KDONOUGH1386
1986 Dodge Daytona Turbo, 2.2L 4 cylinder, with 149,000 miles on it.
I need to know the steps that should be taken to replace a blown head gasket? I can't seem to find a book that gives any such advice. IF you could help I'd appreciate it.
Oct 1, 2007 at 4:32 AM
SERVICE WRITER
  • 9,123 POSTS
Mitchell may be a good bet.
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Couple of points. Replace the head bolts when you do the job. Use a quality gasket set such as fel-pro. When you get the head off, take it to a machine shop, ask them to pressure test it and check for cracks. IF okay, have them machine it. Replace the thermostat at the same time as excessive heat can damage them.
Oct 2, 2007 at 12:27 AM
Suggested Repair
Use a Mitchell manual for the procedure. Replace the head bolts and use a quality gasket set such as Fel-Pro. Have a machine shop pressure-test the head for cracks and machine it if it is sound. Replace the thermostat at the same time because excessive heat can damage it.
Conversation Summary
The owner of a 1986 Dodge Daytona Turbo with a 2.2L engine and 149,000 miles asked for steps to replace a blown head gasket after not finding a repair book. The expert suggested a Mitchell manual, new head bolts, a quality Fel-Pro gasket set, machine-shop pressure testing and machining of the head if it is not cracked, and thermostat replacement.
