1991 Dodge Daytona Won't Start
CADPROF
My step-son has a 1991 Dodge Daytona ES with a 3.0 V6 engine. Last week, on a very frigid morning, he stopped for gas and filled the tank. After leaving the gas station, the car started running rough and with only a top speed of about 40 mph. He called me and I told him to stop and get some dry gas and put into the tank, thinking the conditions had caused the tank to have condensation. When he returned home later that day it was still running rough. I started it when I got home and when I tried to leave it idle, it stopped. I tried to restart it, which it refused to do. It almost felt like it had no compression. I first though the timimng belt was bad, so I removed the valve cover and turned the engine over.... the valves operate. I could smell gas and now I'm wondering if there is some sort of EFI module that is bad. I have spark at the spark plug but wonder if it's hot enough. I'm thinking, ignition coil, distributor cap, or something with the EFI. What about an injector problem? Could it have picked up dirt, if so why would it not start now? Any help would be appreciated.
Jan 27, 2007 at 5:30 AM
  • 110,251 POSTS
Hi:
The spark should be a good snaping blue spark. As far as the gas smell, if the fuel isn't burning, you will smell it. Make sure the catylatic converter isn't plugged and look closely for vacuum leaks.
Let me know what you find.
Mar 11, 2009 at 2:22 PM
Suggested Repair
Confirm the spark is a strong snapping blue spark. Because unburned fuel will smell like gas, check that the catalytic converter is not plugged and inspect closely for vacuum leaks.
Conversation Summary
A 1991 Dodge Daytona ES 3.0 V6 began running rough and limited to about 40 mph after a cold-morning fill-up, then stalled and would not restart. The owner confirmed the valves still move, smelled fuel, and had spark, and suspected the coil, distributor, EFI, or injectors. The expert advised verifying a strong blue spark and checking for a plugged catalytic converter and vacuum leaks.
