1991 Dodge Daytona No Idle Fault Codes
DAYTONAGUY06
I have a 1991 Dodge Daytona which I just put a new motor in. I had it idling for a few seconds with the idle going up to 2500 rpms down to about 300 and back up then it dies. Well now it won't idle at all and I check fault codes, and theres 6.
Fault codes:
11 = No ignition reference signal during cranking OR timing belt skipped teeth or loss crankshaft position sensor.
12 = battery or computer recently disconnected.
15 = No speed/distance signal
24 = Throttle position sensor over 4.96V
25 = Automatic Idle Speed motor driver circuit shorted OR target idle not reached OR vaccuum leak found
41 = Alternator field control circuit open or shorted
55 = end of codes
Thanks
Oct 16, 2007 at 11:40 AM
BMRFIXIT
  • 19,053 POSTS
[quote:d2d6e9320f="daytonaguy06"]I have a 1991 Dodge Daytona which I just put a new motor in. I had it idling for a few seconds with the idle going up to 2500 rpms down to about 300 and back up then it dies. Well now it won't idle at all and I check fault codes, and theres 6.
Fault codes:
55 = end of codes
Thanks[/quote:d2d6e9320f]
You’ve replaced the engine on it
Check all the wiring and connections check the dist
And make sure the TPS sensor not stuck at WOT
That will stop the fuel to the engine
Reset the ECM and try again
good luck
Oct 16, 2007 at 12:24 PM
Suggested Repair
Check all wiring and connections and the distributor. Confirm the throttle position sensor is not stuck at wide-open throttle, which can cut fuel. Reset the ECM and retest.
Conversation Summary
The owner of a 1991 Dodge Daytona installed a new engine. It briefly surged between high and low idle, then died and will not idle. Codes 11, 12, 15, 24, 25, and 41 are stored. The expert advises checking wiring, connections, and the distributor, verifying the TPS is not stuck wide open, then resetting the ECM.
