ok i pulled p0748 code from my 97 dodge dakota has v6 and 155825 miles so i replaced all solenoids and pressure sensor still geting the same code i can shift but only manually overdrive wont engadge i think o/d is computer controled also acts like it has bad gas but not all the time also i here a relay clicking on or off now and then where the fuse panel in the cab but i thought the trans relay is under the hood witch i checked that also by switching it out with one of the others on the same fuse panel
its driving me crazy so i called dodge dealer to put on there computer and they say with as many miles i have i need a new transmission with as much smarts i have i think its not mechanical its computer controled i think its not geting a signal from pcm to trans also does dealer computer pull and dig deeper than my actron hand held scaner can any one help me thanks
Apr 21, 2007 at 2:38 AM
