[quote:df89ea8dfb="rasmataz"]
I would recommend a check on the vehicle speed sensor it takes the place of the governor in a conventional hydraulically controlled tranny.
Further the computer uses this signal to control shift points and the operation of the lock-up clutch
Should be at the tail shaft of the tranny.[/quote:df89ea8dfb]
Ok so I went ahead and replaced the speed sensor. That didn't fix the problem. My code is still there, and my power loss is still significant. It's still got no take-off. Once you hit a freeway speed, it's got pretty good pick-up, but it's like it doesn't have a passing gear. I did disconnect the battery after changing it to reset the system. Oddley, enough, it got rid of all my other codes (0132, 0420, 0442, 0456). However, P 0748 is still there. Thanks ras, for following up with me.
May 20, 2007 at 1:59 PM
