Oil pressure drops to 0
CARBON0
I just bought a 99 dakota 5.9 liter, ran great for about 3 weeks, then all of the sudden after i had punched it and got moving pretty fast i slowed down and the check gauges light/buzzer came on and i noticed my oil pressure had droped to 0...i coasted for a second then it came back up, shruged it off and didn't think anything about it, about 2 days later it happened again (twice in one morning) so i checked my oil and there was NO oil on the dipstick, but i had changed the oil about 2 weeks before this happened and put 5 quarts in it, i know it didn't leak anything out, put a quart in it to get it home to be on the safe side, any clue on what could be going on? oh also it does it sometimes going around the turn, buddy of mine told me it might be sending oil up to the engine but not back down into the oil pan.
Feb 7, 2007 at 9:24 AM
  • 75,988 POSTS
Is it making noise-if not find out what turns the pump.
check the oil pressure with a gauge
Feb 7, 2007 at 11:10 AM
CARBON0
can here some type of noise but it sounds like a heat shield rattling around, but i heard that before this started happening
Feb 8, 2007 at 10:31 AM
ALINKCAZ
I have a '92 dakota with 200k miles and had the same problem with the oil pressure bottoming out. It is sludge build up blocking your oil pump. My truck would lose pressure until it warmed up.
You will need to drop the oil pan and clean off the screen to the oil pump. If your model is like mine, go ahead and replace the oil pump because you will have to pull the engine up anyway.
Hope this helps.
Feb 12, 2007 at 2:49 PM
  • 75,988 POSTS
Okay its the heat shield for the racket.
Sludge is a bad thing the only sure fire fix is to drop it and clean out that nasty stuff
No shortcut with engine flush-sometimes it make things worst.
Good Luck!
Feb 12, 2007 at 7:57 PM
