I don't know what "nothing" means. Do you mean you checked the relays and they weren't there? There's nothing wrong with them?
If you can hear the fuel pump run for one second, we know the automatic shutdown relay is turning on and the Engine Computer has control of it. Next we need to determine if it turns back on during engine rotation. That means you have to check for 12 volts to the ignition coil for that initial one second or while a helper cranks the engine. There had better not be 12 volts to the ignition coil when the engine is not cranking or running. If it's easier to take a measurement on, you can use either smaller terminal on the back of the alternator, or the wire that is the same color at every injector. That's usually a dark green / orange wire, but on some models it's dark green / black.
Have you read the diagnostic fault codes yet? If you have, what were the numbers? You can go here:
https://www.2carpros.com/trouble_codes/obd2/p0300
to see the definitions, or I can interpret them for you.
Jan 7, 2021 at 7:16 AM
(Merged)
