How do you turn off the 'air bag' light?
DODGE DAKOTA
GLIMMER31
2003 Dodge Dakota Crew Cab
3.9L V6 99000mi
While having a new radio put in my Dakota, they disconnected the passenger air bag turn off switch, which set the 'air bag' light. My local Dodge Dealer wants $75 dollars to put their 'reader' on it to clear it. I have an OBDII reader, but an engine code clearer won't do it. How can I turn it off without a special reader? I've tried the OBDII and took off the neg. cable overnight. So far, no luck. Any Ideas? Thanks in advance.
Aug 2, 2007 at 7:44 AM
  • CERTIFIED EXPERT
  • 53,872 POSTS
THe light will no go off unless the problem has been fixed which is probably an impact sensor is unplugged or bad. You must scan the air bag system to get the codes a code reader will cost about $110.00 on Amazon.
Here is a video to show you how to do it.
https://youtu.be/gnSGfEqrf_w
Cheers, Ken
Dec 20, 2017 at 6:35 PM
