ABS Light and Emergency brake light
DABOOCRU02
  • 18 POSTS
2000 dodge dakota 3.9 V6 5spd 4WD The check engine light and the ABS light are both on. I think they came on at the same time. I was not driving the vehicle it was returned to me that way. Also noticed the speedometer is a little lazy. It only works above 12-13 mph. Any ideas.
Oct 17, 2007 at 7:47 AM
MERLIN2021
  • 17,250 POSTS
This sounds like the vehicle speed sensor is causing the issue here is the location.
Left side of transmission in tail housing - Or in the rear differential.
This guide can help as well
https://youtu.be/rTtAnsOlZU4
Oct 17, 2007 at 8:07 AM
DABOOCRU02
  • 18 POSTS
Check for leaks and didn't find anything to the best of my lnowledge and the master cylinder is to the full line.
Oct 17, 2007 at 8:29 AM
MERLIN2021
  • 17,250 POSTS
That lazy speedo, has it turned on the check engine light yet? That sounds like a VSS, and could affect the operation of the computer to sense vehicle speed!
Oct 18, 2007 at 11:08 AM
ORCHIDBS
My 1999 dakota seems to have the same problem. exept my speedometer wouldn't start untill i reached 40 mph, then it went to 55mph. then it just stoped. I have no cruise control. I replaced the spped sencor in the back of the transmission, but to no avail. Brake light and abs light came on at the same time. Check engine light a short time after.........can ya help????
Oct 20, 2007 at 1:55 AM
DABOOCRU02
  • 18 POSTS
The check engine light is on and the code is P1491. Rad control fan relay. I have another post in as well on that problem but i think that i have it resolved thanks to this site. But as far as the check engine light being on this is the only code that i am getting. Not sure what VSS is but i think you are talking about the vehicle speed sensor. I am replacing the abs speed sensor located on the rear differential (if that is what you are referring to) to see if that fixes the problem. I will post any results that i have. Please reply with what the VSS is and if it is what i am talking about. Thanks for the help so far it is greatly appreciated to help eliminate all possibilities
Oct 20, 2007 at 4:26 AM
MERLIN2021
  • 17,250 POSTS
You might also want to check the body control module, if multiple systems are failing...The Valve on the differential is the anti-lock fo the rears...works off the ring gear.
Oct 20, 2007 at 5:50 AM
DABOOCRU02
  • 18 POSTS
The ABS Speed sensor located on the rear differential was replaced and it fixed the problem. The check engine light and the brake light are not on anymore. It was explained to me that only trucks that have rear drums brakes have a speed sensor on the differential. The speed sensors for the abs on four wheel disc brakes is located at the wheel. Hope this helps.
Oct 24, 2007 at 1:19 PM
BSCHMIDT10
My abs and brake light instrument light are coming on and I'm getting a rubbing noise from the front right wheel.
I'm getting 2 codes from a reader:
65 - internal main relay open
23 - Intermittant signal open from Rt front sensor
and rt front sensor open/intermittant
I'm guessing my right front sensor is going bad? Was looking for some better explanation as to what the codes mean, and what I have to do to fix them.
Appreciate the help
Sep 29, 2019 at 10:25 AM (Merged)
BMRFIXIT
  • 19,053 POSTS
[quote:c25b6c55a7="bschmidt10"]Computer problem
1999 Dodge Dakota V8 Four Wheel Drive Automatic 92000 miles
Appreciate the help[/quote:c25b6c55a7]
check front wheel bearing and sensor 1st
check fuses and relays
check brakes and fluid
PLATINUMPRINTER
The ABS & Parking break idiots come on together. They act like a sensor is reading a sloshing liquid. The break fluid reservoir is full. Any ideas?
SERVICE WRITER
  • 9,123 POSTS
See what codes are listed in the computer.
The codes may give a starting point, but may not have any listed.
IF none, the stop light switch circuit should be tested first.
2CP-ARCHIVES
  • 4,540 POSTS
My ABS light and brake light come on every time I hit a bump. What is causing this, and how do I fix it?
CARADIODOC
  • 34,413 POSTS
Start by checking the level of the brake fluid in the reservoir. Be absolutely certain to not get any hint of grease or other petroleum product in there. Also, don't fill the reservoir. Just add a little fluid, then have the front brakes checked.
SCIENCE GUY 2
96 Dodge Dakota - replace rear cylinder, bleed line. Brake fluid full, disconnected battery and warning lights still lit.
Started truck up in morning and while driving to work warning lights lit up
brake fluid low filled back up after looking discovered wheel cylinder needed replacing.
SATURNTECH9
  • 30,869 POSTS
You need to get the truck scanned for codes and let me know what the exact code numbers are.Thats our starting point.
BIGDUNN78
I just did a brake job on my rear drum brakes and my passenger side wheel moves in drive but my drive doesn't but does in reverse my emergency brake light is on but it is not on what could be the problem?
CARADIODOC
  • 34,413 POSTS
Your description and lack of punctuation are rather confusing. Are you observing the wheels rotating while the truck is still jacked up? Have you tried driving it? If so, what were the symptoms then?
When you had the drums off, do you know how to check if the parking brakes are fully released on both sides?
BIGDUNN78
Sorry I was in a hurry before, and yes when on jack stands the tire moves without any problems. And everything looks right when I take the drum off and I can see the parking brake is released. But when I put the drum on and the tire and take off the jack stands my passenger's rear tire is moving in drive but my drivers rear is not. Both wheels do go in reverse I'm just having problems with the drivers side rear going into drive. I've checked the emergency brake cable and there's no tension on it, and the shoes have been adjusted to drum.
CARADIODOC
  • 34,413 POSTS
Dandy. I think you're expecting to see something that isn't going to happen. It is very rare for both wheels to spin at the same time unless you have a locking back axle. "Sure Grip" was Chrysler's trade name, but most people go by "Positraction", which is GM's trade name. A single wheel spinning is the result of one side having slightly more resistance than the other. When both tires are on the ground, everything will be fine. If you block the wheel that spins, you'll see the other one starts to spin. That's what the differential does. That difference in resistance is due to one brake being adjusted slightly tighter, more drag on an axle seal, a tighter wheel bearing, etc.
To prove to yourself this is what's happening, you can stick something through the wheel that spins, or place a 2" x 4" under the tire, then slowly lift it up like a lever. Be real careful though. I've had tires catch the board and send it shooting out. That can be dangerous.
The different wheels rotating in different directions is surely a result of how the brakes are adjusted. Drum brakes are real effective even without a power booster because they self-apply. What I mean is when one shoe starts to contact the drum, it tries to rotate with it, and that applies the other shoe through the star wheel adjuster on the bottom. The first shoe sticks to the drum and tries to apply the other shoe harder and harder. That doesn't occur easily when there's just a little drag on them and the brakes aren't being applied, but it creates enough resistance that one wheel rotates one way and the other wheel rotates the other way.
Next, we gotta clarify the parking brake issue. There should be tension on the cables when it's released. Given the symptoms, it's real likely one or both rear cables are sluggish from rust and is not fully releasing. You need the tension of the brake shoe return springs to pull the parking brake pedal up. That will turn the switch and "Brake" light off. First, look at the rear cables where they come out of their outer casings. The front of those casings will be anchored to a bracket pretty near the front leaf spring mounts. If the first 1/2" of either cable, right where they exit the casing, is shiny, that cable is not fully retracted. Try flexing that casing to see if spring tension will pull the cable in. If it does, that cable should be replaced. Never try to lubricate a parking brake cable. That will never fix it, and with a customer's vehicle will almost always end up with the vehicle being towed back to the shop for a wheel that's locked up.
Next, with the drum removed, look at the two shoe frames where they contact the large anchor pin at the top. If either shoe is not against that pin, the parking brake cable is holding them partially-applied. Assuming you're able to get the drum on, that will cause real easy rear-wheel lockup under light braking. Even if this is okay, look at the parking brake strut bar between the middle of the two shoes. You should be able to push that bar toward the front of the truck, against the anti-rattle spring pressure, with your thumb, about 1/8". If the parking brake cable is stuck in the partially-applied position, the lever hanging from the rear shoe will be pushing that strut bar toward the front shoe, so it will be tight. Here again, the fix is to replace the sticking cable.
This all assumes a parking brake cable is indeed sticking. If this was a Ford product more than a year or two old, I could guarantee that is the problem because they have so much trouble with their designs. The clue that this is causing your problem is the sagged parking brake pedal. If it weren't for that, there's up to two other things that will turn on the red "Brake" warning light. One is a tripped pressure-differential valve. That valve moves when the front or rear half of the brake hydraulic system doesn't build the same pressure as the other half. That occurs when one system has a leak, which can be a rubber hose, a steel line, a leaking rear wheel cylinder, or internally leaking inside the master cylinder. On Chryslers and GMs, that valve is spring-loaded and should reset as soon as you release the brake pedal, but it's fairly common for them to stick. A good, hard jab on the brake pedal almost always gets them to release, then, once it's centered in its bore, the switch will turn off. To tell if this switch is causing the "Brake" light to turn on, follow the two steel brake lines from the master cylinder down to the brass "combination valve" on the frame rail. In the middle of that block you'll see a single wire plugged in. Unplug that wire. If the light goes off, that valve needs to reset. Try doing that on a Ford product where they aren't spring-loaded. That can lead to an afternoon of frustration!
The third switch, which not all vehicles have, is a low-fluid level switch on the reservoir for the master cylinder. If the fluid is low and it's not because you were bleeding the system or had a leak, don't fill it. The main reason for it to be low is worn front brake pads. As they wear, the pistons come out of the calipers to self-adjust. To install the new, thicker pads, you have to push the pistons back into the calipers, and that pushes all the fluid behind them back up into the reservoir. If you filled the reservoir previously, the fluid will spill over and make a mess. Brake fluid will eat paint too. If the fluid is low, add just enough for the light to turn off, then inspect the front brake pads.
