2002 Dodge Dakota Backfiring
SHILO11
my 2002 dodge dakota 4x4 sport has 80.000 km. it is missing and running rough. it is back firing and very hard on fuel.just had tune-up at dealer. new spark plugs, wires and distrubitor cap and rotary button but the problem presists. what do you suggest I do to correct this problem.
austin fowler
Jun 5, 2007 at 10:53 AM
E40WATER12
  • 522 POSTS
Heres a few things to look into:
1. Are u getting check engine light on? Could have a problem with youre emission control system, Is not functioning properly. O2 sensors / TPS sensor / EGR valve soliode etc.
2. Faulty spark plug gap / Wires / coil packs.
3.Could have a problem with youre fuel pressure regulator, Or injectors, Also Injector vaccum leak at the injectors, Intake manifold / Or vaccum hoses.
4. Or youre timing is out a few degree's, Also youre cyl hd valves could be burnt.
Good Luck.
Jun 5, 2007 at 8:43 PM
Suggested Repair
Scan for a check-engine light and emission faults such as O2 sensors, TPS, or EGR solenoid. Recheck plug gap, wires, and coil, then test the fuel-pressure regulator, injectors, and vacuum leaks at the injectors, intake, and hoses. Also verify ignition timing and inspect for burnt valves.
Conversation Summary
A 2002 Dodge Dakota with about 80,000 km misfires, runs rough, backfires, and uses excessive fuel even after new plugs, wires, distributor cap, and rotor. The expert recommends checking emission sensors, ignition components, fuel pressure and injector vacuum leaks, timing, and possible burnt valves.
