1998 Dodge Dakota No Cat Converter
MPJP5811
98 dodge dakota 4X4, 5.2l, I have an unknown problem that I am trying to fix on my truck, am trying to narrow it down, and found the previous owner had removed the converter, could this lead to any problems with overall performance, if so what?
Dec 23, 2006 at 8:07 AM
1992 DODGE SPIRIT
  • 7 POSTS
No, a removed cat converter wouldnt cause a performance prob but your car needs one on it... its against the law to have a car without one cause of emissions and what not... atleast where i live its against the law to drive a car on the road without a cat converter
Jan 16, 2007 at 2:28 PM
SERVICE WRITER
  • 9,123 POSTS
That would be federal law!!
The O2 sensors wouldn't like it and at the very least throw a code and a cel.
Jan 16, 2007 at 4:59 PM
  • 75,988 POSTS
If you're not subject to the annual IM-240 program its okay-but polluting the air that people breaths is a No-no under the clean air act IAW the EPA In the US wide America.
Further-your A/F demand is not being adjusted properly w/o the O2 signal.
Jan 16, 2007 at 7:28 PM
KOBY
  • 28 POSTS
There is a reason the converters are on there....Its the law for one, and to control back pressure in the exaust. By removing the cats in a non-high performance engine can polute the engine in time because it doesn't have a equal amount of flow. The O2 sensors don't know what to think so it sends a signal to everything to readjust, causing the engine to not run like it should from the manufacture. In time it will cause different problems. Put the cats back on and make sure your valves aren't burnt.
Jan 19, 2007 at 11:07 AM
Suggested Repair
Reinstall the catalytic converter, check for trouble codes and proper oxygen-sensor feedback, and inspect the valves for burning if the truck has been driven without the converter.
Conversation Summary
The owner of a 1998 Dodge Dakota 5.2L found that a previous owner had removed the catalytic converter and asked whether that could affect performance. Replies said operating without a converter violates federal emissions law, can upset oxygen-sensor signals and air-fuel control, trigger a check-engine light, and change exhaust backpressure. The recommended action was to reinstall the converter and check that the valves are not burnt.
