89 dodge dakota axle leak
TONY63
my 89 dakota 4x4 has fluid coming out into breaks on one wheel.what is easies fix.think it is coming from axle.truck has 117000 miles. thank you
May 20, 2007 at 4:25 AM
E40WATER12
  • 522 POSTS
Is it fluid leaking from the drum area? I would take off the rear brake drum, Could have a wheel brake cyl wornout, Or an axle seal.
May 23, 2007 at 9:49 PM
TONY63
thanks for reply. i beleive it is axle leak.do i have to get into diff gears to replace seal. is it a complicated fix. thank you
May 24, 2007 at 7:59 PM
