1987 Dodge Dakota EGR Light
KDWHICH
I have a check EGR light on the dash. Truck has 70,000 miles. EGR seems to be OK. How do I turn dash light notification off? Have tried disconnecting the Neg. battery terminal w/o success. Thanks
Dec 27, 2006 at 9:00 AM
SERVICE WRITER
  • 9,123 POSTS
The egr light comes on periodically at 52,500, 82,500 and 105,000 miles. A digital electronic module needs to be reset. This is a reminder to do the emissions maintenance. Since we know you just did all that, now you need to reset the module. Have a 9 volt alkaline battery on hand to replace the one in the module as you reset it. Do not disconnect the wiring connector to the module especially while the battery is out! So slide the module out, insert a small screwdriver into the small hole on the module case and close the switch. Take off the module cover for the battery and replace it. Return the module to the mounting bracket. :)
Dec 28, 2006 at 10:05 AM
KDWHICH
Have looked for the module you referred to. Unable to locate. Is it under dash? or in the engine compartment? Once found I'm sure I can reset and change battery. :?
Dec 29, 2006 at 6:38 AM
SERVICE WRITER
  • 9,123 POSTS
There should be a small blue box locate just above the emergency brake mounted on a bracket below the headlight switch on the back of the instrument panel.
Dec 29, 2006 at 11:33 AM
Suggested Repair
The EGR dash light is a scheduled emissions reminder, not proof the EGR valve failed. Reset the digital module and replace its 9-volt alkaline battery. Do not unplug the module connector, especially with the battery removed. Slide out the small blue module above the emergency brake, on a bracket below the headlight switch behind the instrument panel. Close the reset switch through the small hole with a screwdriver, replace the battery, and remount the module.
Conversation Summary
The owner of a 1987 Dodge Dakota with 70,000 miles has a check EGR dash light and could not clear it by disconnecting the battery. The expert explained that the light is a periodic emissions-maintenance reminder at set mileages and that the electronic module must be reset while its 9-volt battery is replaced. The owner could not find the module, and the expert located it as a small blue box above the emergency brake, mounted below the headlight switch on the back of the instrument panel.
