2004 Dodge Dakota howling noise
56,000 MILES • 6 CYL • 2WD • MANUAL
BEREK82
There is a howling noise coming from my truck somewhere when i get up to cruising. It stops when i let off the gas pedal or push it to speed up. It happens in any gear that i am cruising in regardless of rpm, load, or road conditions. Can anyone tell me where this noise might be coming from?
Jan 8, 2009 at 7:42 AM
  • 110,248 POSTS
Hi:
Does it sound like it's coming from the front or rear? Mos likely it's a bearing but I need to know what area it's coming from. Does it change when you make turns...
Jan 8, 2009 at 12:48 PM
BEREK82
It does not change when turning. It sounds like it is coming from the rear of the truck.
Jan 12, 2009 at 3:33 AM
  • 110,248 POSTS
Hi:
what I suggest is to have the rear differential serviced and checked for excessive play. Many of the differentials in these trucks develop play in the differential which require shims to repair. Let me know what you find.
Jan 12, 2009 at 5:44 AM
BEREK82
Thank you I will get the info here as soon as i can.
Jan 12, 2009 at 8:30 AM
