2003 Dodge Dakota cooling system pressure-up
112,000 MILES • V8 • 4WD • AUTOMATIC
TIZZ101
Hi-just noticed the other day alittle coolant under the front of my truck and under investigation found it to be leaking past the hose clamp on the upper hose where it attaches to the rad. The leak is due to excessive pressure because the clamp/hose are good and tight. What the heck? I think it may be the thermostat not opening? The truck is not overheating which confuses me. Also-I noticed the coolant was down (way down) so I topped it up thinking press. was from lack of coolant. Turns out it's not-even with full coolant still pressures up.Help! I don't own a credit card :(
Apr 21, 2009 at 12:03 PM
BLACKOP555
  • 10,386 POSTS
the clamp could be bad. take that clamp off and put on a new hose clamp the kind with the slots cut in it with a worm gear for tightening it. use that to tighten it. those factory kinds dont work at all.. also make sure the clamp is past the rib on the line. that is important to stop coolant flow.
Apr 22, 2009 at 1:45 PM
TIZZ101
the clamp is not the issue-like I said the leak is only there do to excessive press-I noticed alittle leak under the water pump-if the pump was'nt working right would that cause the excessive pressure?
Apr 24, 2009 at 1:44 AM
BLACKOP555
  • 10,386 POSTS
if the pump was bad there wouldnt be much pressure at all.
the only thing thats going to cause high pressure is a leak in the headgasket. a cracked head. or a crackec block on the cylinderwall. or water not antifreeze in the cooling system.
Apr 30, 2009 at 1:19 PM
