1994 Dodge Dakota radiator transmission hoses
1994 DODGE DAKOTA
145,000 MILES • 6 CYL • 2WD • AUTOMATIC
IRISHOB
How do you disconnect the bottom radiator transmission hoses from the radiator. There is a nut on the radiator which I've unloose but I cannot pull the aluminum line out. It looks like some compression fitting.
Sep 29, 2010 at 6:33 AM
  • 110,244 POSTS
There is only one nut that holds it into the radiator unless an adapter was installed. Once you loosten the nut, it should pull out. Check to make sure there are no clips holding the line from moving.
Let me know what you find.
Oct 1, 2010 at 12:59 AM
IRISHOB
You're right. There is only one nut on each transmission hose, but they don't pull out. A friend told me to buy a special tool that will take it apart. Thanks, Tom
Oct 1, 2010 at 1:15 PM
  • 110,244 POSTS
It should pull out when you loosten the bolt.
Oct 1, 2010 at 5:11 PM
