2003 Dodge Dakota Cause of problem leading to repair (compl
2003 DODGE DAKOTA
40,460 MILES • V8 • 4WD • AUTOMATIC
SMYLIE51
The engine light came on. Took vehicle to Dodge for repair. Their diagnosis: Performed tests on purge valve and checked inside lines and found white substance all through line. Removed charcoal cannister and found it plugged with white substance. Removed and replaced purge valve and cannister and cleaned out lines.
They didn't mention what the white substance might be. Do you have an idea, and can I eliminate this issue in the future or is it a common issue? Would a change from years of gas with ethanol to ethanol free gas cause a problem?
Apr 1, 2010 at 7:57 AM
  • 110,240 POSTS
The fuel change wouldn't cause it. To me it sounds like you were getting moisture mixing with oil or gas that caused the substance. I don't know if you fill your tank each time you get gas, but if you do, don't overfill it. That can cause fuel to get to the charcoal canister. When the pump stopps, it's full.
Apr 2, 2010 at 1:38 PM
  • 110,240 POSTS
Two things, first thanks for the positive feedback, and you are welcome for the help. Let me know if you have other questions and thanks for using 2carpros.com.
Apr 5, 2010 at 1:33 PM
