First i have no codes on lights that come on. At a speed that starts at 60 mph and goes to 65 mph, i get a vibration that is not a tire or wheel vibration. It is like you wold get if the engine mount was bad. At this time , the sound of the engine also changes. It gets a different deeper sound. If i go to passing gear or go below 60 mph or above 65 mph it goes away. But as soon as i go in that range it comes back . it does not matter if under load or not. At the same time as this started , i started getting a noise when shifting between gears. When still, if i shift between drive and reverse, I get a noise the sounds like a creaking door and lasts a couple seconds. Like it is slowly going to gear. Please help Joe
Aug 14, 2010 at 5:42 AM
