2002 Dodge Dakota 4 wheel drive
ANDREWHN1
  • 2002 DODGE DAKOTA
  • 6 CYL
  • 4WD
  • 167,000 MILES
I have a problem with my 4 wheel drive. It turns on with a switch on the dashboard. I am not getting any lights on 2 wheel or 4 wheel at the switch and the 4 wheel is not engageing. I checked for a fuse problem but didn't find a problem. Any help would be most appreciated.
Andrew
Thursday, May 27th, 2010 AT 5:08 PM
  • 109,858 POSTS
Andrew:
Check to see if you are getting power to the actuator on the transfer case. Let me know what you find.
Friday, June 4th, 2010 AT 11:02 AM
ANDREWHN1
Hi Joe you answered my question about my 4 wd problem with my dodge. You asked me if I had power to the actuator. I just got the chance to check it and I do not have power going to it. Any advice would help.
Andrew
Wednesday, June 9th, 2010 AT 4:07 PM
  • 109,858 POSTS
Hi:
If there is no power there, you have to work backwards. Check to see if there is power to the switch. Also, under the hood is a power distribution box. I believe there is either a relay or fuse in there for the actuator. Check that and make sure power is getting to it.
Wednesday, June 9th, 2010 AT 6:30 PM
