4 wheel drive light is on
REMY1975
  • 2002 DODGE DAKOTA
  • V8
  • 4WD
  • 132,000 MILES
4 wheel drive light is on . And no light on the switch 4hi 4lo 2hi im stuck in 4 wheel drive, a can't switch to 2 wheel drive what can a do to fix the problem?
Sunday, January 10th, 2010 AT 1:36 PM
  • 109,885 POSTS
I need you to check to see if there is power to the 4wd actuator on the transfer case. If it won't come out of 4wd, chances are there is no power to it or the actuator is bad.
Wednesday, April 14th, 2021 AT 6:22 PM
